Convection oven
thepetographer
Re: Convection oven
Post by thepetographer »
Hi anyone have any experience with using a fan forced convection oven
I used 15mins at 200 and it was nearly alright but vey patchy
Re: Convection oven
If patchy, I would think they aren't getting hot enough, or your wraps aren't tight enough - I would try them for longer - if there is any way you can rig up an oven thermometer sitting inside the mug, that you can see from outside the oven, to see when the mug gets upto temp it may help.
thepetographer
Re: Convection oven
thanks pisquee ------it maybe the oven ---- i put the bowl in and turned the oven on ----- but it is not like a normal oven u can warm it to 200 --------- the fan just blasts air ----- I had a thermometer sitting in the bowl ---- and it was right at the bottom of the bowl -------- I only have 1 bowl left and its along weekend here so cant get any more -------its not far off --- so I might just give it another 5 mins and tighten up the wraps a notch
