"Comparisons are odious"
Discuss other print methods.
Greybeard
Re: "Comparisons are odious"
Post by Greybeard »
I've no idea who said it first, but it'll do for an eye grabber.
As a newcomer to the forum, I've been trying to get some basic principles fixed in my ancient head so that I can compare the pros and cons of various methods.
Dye sub is OK, and DTG is getting there, but I'm sure there are lots of others, so my first question is there any place in the forum (or outside it for that matter) where a general line up might be found ?
I suppose what I'm looking for is a tick list of current processes to help me cover the ground a bit quicker.
The details need only be very sketchy, just enough to give an outline.
The high res detail can be filled in later...:smile:
John
It's like doing jigsaw puzzles in the dark.
WorthDoingRight
Post by WorthDoingRight »
Well John, I am not aware of such a list but reading your post I assume you are after methods of embellishing a plain t-shirt.
So here is a list of methods I am aware of, I am certain others can add to the list in this thread.
There is as you say Dye Sublimation, using sublimatable inks that can be used to decorate a high polyester content shirt. There is DTG where normally after pre-treating the shirt a printer prints directly on to the shirt with a printer. There is screen printing where ink is transfered through a fine mesh to leave a pattern of ink on the shirt. There is decoration using hand paints that you either paint on or airbrush on to the shirts. There are both laser and inkjet transfers where you print onto a transfer paper that is then applied to the shirt with a heat press. There are flex and flock materials that you cut out and stick to the shirt with a heat press. There are rhinestones and sequins that you again heat press onto the shirts and finally there is embroidery that you sew onto the shirt. Not sure what I have missed but I am sure someone will let us know soon enough.
Richard
Greybeard
Post by Greybeard »
Thanks Richard.
Obviously I should have added a bit more detail re what sort of product, but I'm being a bit coy about it.
Suffice to say that I have been approached by someone with an intriguing problem relating to my own expertise, but which I never solved.
Printing technology now is hardly recognisable from my early days in business, and it seemed to me that if I started again, I might just find a solution.
I'll add that I need to be able to place a customer supplied image onto an object that is flat while held in a purpose build carrier, which would be about 3/4" - 1" thick, with the maximum image size within A3.
Print runs might be 100 - 200, but the key has got to be fast turn around - almost "just-in-time" printing.
John
WorthDoingRight
Well John, sorry to say that without an idea of what the object is made of that needs the image attaching this is a not going to be an easy item to assist with and I for one have no great ability to imagine an image of the item from your description. Perhaps someone else will be able to advise you that can see what you are trying to achieve in their minds eye.
Richard
Greybeard
Post by Greybeard »
Sorry Richard, senior moment there..:redface:
The top surface, to be printed, will be a polyester or a polycotton mix fabric.
John
Greybeard
Post by Greybeard »
I realise that dye sub seems the obvious way to go, but since joining the forum and seeing other processes, like DTG, I thought I should ask the question.
This might help me more quickly get up to speed on any alternatives that might be worth investigating by virtue of a faster cycle time, for instance.
Living as I do within the proverbial stones throw of Listawood, this alone might be a good indicator of which way to go !
John
WorthDoingRight
Well polyester or a high % polyester cotton fabric is suitable for dye sublimation and if it is mounted on a 1" thick mount that allows a swing arm press to swing over the top and press the paper to your material then it might be the way to go. However is the material mountable to the 1" thick carrier after printing? if so many other methods may be suitable also.
Greybeard
Post by Greybeard »
WorthDoingRight;54450 wrote:..........However is the material mountable to the 1" thick carrier after printing? if so many other methods may be suitable also.
Unfortunately no, and this is the major problem, and why I checked out DTG, and then I saw the capital investment required - ouch !
I do have a couple of gelsprinters, a Gx2500 and a Gx3000, so I'm familiar with that type of inkjet, and did once successfully get them to print on a white stiffened polyester silk fabric.
It would be an interesting challenge to hack one of those to print on a 1" thick block, but that's a different problem.
John
WorthDoingRight
Well there are a few youtube videos of hacked epson printers being used for DTG purposes - maybe have a look and see :-)
Greybeard
Post by Greybeard »
Thanks Richard, but that will have to be tomorrow. Well past my bedtime !
John
