I need to BULK marge images, however the top layer has a WHITE outer that needs to go, as the bottom image is BLACK, so all that is left is the main image?
image an A4 transfer, that needs to be cut before being used...........on a black hoodie
ANY HELP??
Merging images together
- mrs maggot
Re: Merging images together
what design programme are you using ? you will need to give more information for people to help
If people would be able to tell me what progammes they use? as I have just about most major graphics programmes out there and a few freebie ones. I normally use 'merge' for simple over laying, but maybe I need to create a script in Corel photo shop or something and run that on batch processing?
Are you trying to merge 2 images into one or create a process wher multiple images can be merged together?
