Need help with print
NIGELG
Re: Need help with print
Post by NIGELG »
Hi all,
I have a rush job on this weekend and my printer is playing up i use an
Epsom 1290 with artanium bulk ink system and inks and true pix paper.
I was experiencing a problem printing in black with text not being sharp and has suddenly started to be smeary or ghostly around the edges like the ink is being spread out somehow.
i purchased a new bottle of black ink to top up system as it was running low and keep pressure in lines.
It seemed to clear it but today i have gone to print a job out and its back any ideas why Image
I have done the nozzle check etc and all seems OK just this blurryness on the black
can you check normal paper? general use one.
NIGELG
Post by NIGELG »
Thanks for contacting I gave up in the end and purchased a new Epson 1400. I was trying to save a bit of money on the bulk ink system and ordered an empty one from a company on ebay sunday night as they are not far from where i live about 30 miles. I thought i can transfer my inks from my old system. And bugger me it hasnt arrived, tomorrow is my last day or i loose the job. It's for valentine samples for selfridges! :x
so fingers crossed for tomorrow Image
Stitch Up
Post by Stitch Up »
Where you located Nigel?
NIGELG
Post by NIGELG »
Brighton
Stitch Up
Post by Stitch Up »
Bit to far from Wales!
Good luck.
NIGELG
Post by NIGELG »
cheers
you should say you have a dead line! i am sure me or somone else would print few pages for you. so you can press your samples and get this job.
JSR
Post by JSR »
Are you trying to print black-ink only when you get this "spraying" issue?
My 1400 has issues printing black-ink only (greyscale) - probably because it's a bit old now - but if I don't check that box, it comes out acceptable. You lose a true neutral greyscale but you may find it'll get you out of a fix.
Also, with your existing 1290, try turning off anything that makes it print quickly. Turn off "high speed" printing, and set it to print at the highest quality setting you can - anything to slow it down and let it spend its time on the printing.
You may find it helps.
Other than that, I can only wish you luck that your new system arrives in time.
DaveM
Post by DaveM »
Maybe a bit late, but I am only in Bognor Regis if you get stuck and need something printed.
PM if necessary
Regards
Dave
