Mug blanket for Genie 3 Mug press
Jessie
Re: Mug blanket for Genie 3 Mug press
Post by Jessie »
I need to replace my 10/11oz mug press blanket. My press is from Listawood and it's the Genie 3 model and has the 4 pin prongs (pic attached). They're not in stock at Listawood and will take a few weeks to get in. * Does anyone know where else I could get one from that's in stock?
Thanks in advance :)
[ATTACH=CONFIG]7246[/ATTACH]
vB_ID:7246
vB_ID:7246
knightweb
Post by knightweb »
I had the same problem a couple of months ago
Eventually, I found a replacement on ebay (Signzworld), out of stock on thier web site but had them on ebay
I'm not sure if mine is a Genie 3, but my model number mached & is the same plug as your photo. It works fine
https://www.ebay.co.uk/itm/302192639119 ... 2189438678
Jessie
Post by Jessie »
Thank you. I will check it out :)
It's also known as Arc press and you can buy elements from magic touch
https://www.themagictouch.co.uk/product ... t-10-11oz/
Jessie
Post by Jessie »
Thank you - I needed some mugs from there so I can order the mug blanket too.
