Wanted: ST-3042 spare parts
3D Sublimation
BigSmoke
Re: Wanted: ST-3042 spare parts
Post by BigSmoke »
I was wondering if anyone is selling any spare parts for the ST-3042.
My machine keeps shorting when I open the lid. I think the wiring is shot and needs to be replaced.
It heats up fine (both plates) vacuum works as well as the timmer.
But if you move the lid, sometime, it shorts the whole house.
Any helps, recommendations, ideas, or do you know someone who could look at it please, I would be very grateful.
I am based in leicestershire.
Thank you
Rich
pw66
Post by pw66 »
My kettle does that sometimes, usually because there is moisture in the base. Have you checked that your problem isn't as simple as a bit of damp in the mechanism or the plug?
Ravisteam
Post by Ravisteam »
BigSmoke;150849 wrote:Hi,
seach on ebay for faulty machines .
Thank you
Rich
Seach on ebay for faulty machine or Facebook
jtd
Post by jtd »
pw66;150850 wrote:My kettle does that sometimes, usually because there is moisture in the base. Have you checked that your problem isn't as simple as a bit of damp in the mechanism or the plug?
Have you emptied the part at the back under the casing which collects the moisture pulled through in the vacuum?
Sent from my SM-G781B using Tapatalk
