Not sure if this is right forum but please direct me if it’s not.
Inquiring for where I can find dtf suppliers in the Uk for transfers to use on cotton shirt or cotton like shirts. I had seen supacolour touted as one but curious if there’s any others.
Dtf suppliers uk?
Re: Dtf suppliers uk?
They aint cheap £7 for A3 size sheet dtftransfer.co.uk or dtftransfers.uk unless someone can suggest others i can try.
£15 per linear metre @60cm film width seems to be the going rate. Gang as many designs as you need and cut them up yourself.Fletcher;150141 wrote:They aint cheap £7 for A3 size sheet dtftransfer.co.uk or dtftransfers.uk unless someone can suggest others i can try.
This firm seems to be representative - never used them so not a recommendation as such. https://dtftransfer.co.uk/index.php/pro ... transfers/
Keep shopping around, I think that every man and his dog will be selling transfers soon as a way to pay for the equipment.
I highly recommend Curious Newt, i've used them and the quality of the transfers is perfect. https://www.curiousnewt.co.uk/
I'd second that, very impressed with their service!matzy;150635 wrote:I highly recommend Curious Newt, i've used them and the quality of the transfers is perfect. https://www.curiousnewt.co.uk/
Curious Newt offer very quick turnaround and quality is good. Might be quite a bit pricer per m than many others out there but then if you need it in a rush they are a first choice!
