Mug press for sale. Touch screen bnib.
Re: Mug press for sale. Touch screen bnib.
Brand new. Great quality press. You can calibrate heat.
£100 delivered if paid paypal as friend.
vB_ID:5331
vB_ID:5331
vB_ID:5330
vB_ID:5330
Ash Idris
Post by Ash Idris »
Hi, what brand is this product?
Also is it auto or manual and have yoy got a picture of the actual item?
Sent from my SM-G950F using Tapatalk
its made by freesub. and what do you mean by auto or manual?
it does start countdown automatically after closing press if this is what you mean?
Ash Idris
Post by Ash Idris »
Okay that's fine.
I'm literally looking into purchasing a sublimation printer along with a hot press.
And a mug presser was the next thing i'm looking into.
Will defo be in touch in the coming days.
Ash
Paul;132992 wrote:its made by freesub. and what do you mean by auto or manual?
gazfocus
Post by gazfocus »
[MENTION=4]Paul[/MENTION] - Does it heat the mug before it starts counting down or does it start counting down right away?
you can set it to heat to the temperature of your choice before countdown will start.
gazfocus
Post by gazfocus »
Paul;133117 wrote:you can set it to heat to the temperature of your choice before countdown will start.
Sorry Paul, what I meant was, most modern presses have an idle temperature, then when you put a mug in, it detects the temperature of the mug and then heats the mug up. Once the mug is heated to the set temperature, the timer starts to count down.
Is is that how this works or does it start counting down as soon as the press is activated?
gazfocus;133118 wrote:Sorry Paul, what I meant was, most modern presses have an idle temperature, then when you put a mug in, it detects the temperature of the mug and then heats the mug up. Once the mug is heated to the set temperature, the timer starts to count down.
yeah, it has idle temp.
gazfocus
Post by gazfocus »
Paul;133124 wrote:yeah, it has idle temp.
That’s not what I asked. I know I’m not always the best at explaining things but even I don’t think what I’m asking is that hard to understand.
Nevermond, I’ll leave it.
