Large Format Heat Press Advice
eltanno
Re: Large Format Heat Press Advice
Post by eltanno »
I am in need of a heat press with a flat bed able to accommodate a 24" x 14" item. I am looking at these 2 presses. Can anyone give me some feedback on them please?
http://www.subli.co.uk/shop/dye-sublima ... press.html
http://www.subli.co.uk/shop/dye-sublima ... dk25s.html
I am leaning towards the transmatic at the moment, as it has a larger bed. But want to get any advice before shelling out so much money.
Thanks in advance.
Jim
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
I and a few others on here have the A2 Pressmechs, UK made. From my experience I can't fault it.
http://www.pressmech.co.uk/online/index ... ory/view/1
Regards
Janners
eltanno
Post by eltanno »
Thanks for the info, can you tell me what kind of power supply this machine needs, and what the heat distribution is like on the plate? Can you go right out to the edges?
Cheers
Jim
JMugs;122068 wrote:I and a few others on here have the A2 Pressmechs, UK made. From my experience I can't fault it.
Regards
Janners
JMugs
Post by JMugs »
It runs off 240v standard mains. The platen is big enough that there is an overlap hence 24 by 14 inches isn't at the edge. Metal and wood panels print easily.
Regards
Janners
eltanno
Post by eltanno »
So is its just a 13amp normal mains plug?
Jim
JMugs;122078 wrote:It runs off 240v standard mains. The platen is big enough that there is an overlap hence 24 by 14 inches isn't at the edge. Metal and wood panels print easily.
Regards
Janners
JMugs
Post by JMugs »
Yep, normal 13 amp socket.
eltanno
Post by eltanno »
Thanks again for the replies, its all very helpful info. I dont suppose you would mind measuring the plate for me so that I can put my mind at ease on the size of its overlap?
Thanks again,
Jim
can we back up and ask what you are actually wanting to press that's that size to give some perspective to advice that can be given?
