Turquoise colour printing Navy.
Steeki89
Re: Turquoise colour printing Navy.
Post by Steeki89 »
Hi folks,
Having a bit of a Nightmare here.
I have an Epson WF-3010 printer with Dye Sub CISS installed. I also have a custom ICC profile installed which was made specifically for my ink, paper type and printer settings. I have photoshop cs6 set up to use the custom profile when printing, as well as making sure the printer colour management is set to off.
When I first used the ICC profile, it worked perfectly for a mug I designed and printed. But after not using the printer for a week or 2, I am once again having problems with colour print out.
I am trying to print a turquoise colour, and it is printing out a dark navy colour. EDIT: When I sublimate my mug, the turquoise looks better, but the whole image appears darkened and off-tone.
I have cleaned nozzle several times, and used syringes to draw ink through the lines to make sure there's no blockages.
has anyone any ideas what on earth is wrong? :confused:
Cheers in advance.
Edit: PROBLEM SOLVED! - THE ISSUE WAS WHEN I ORIGINALLY PRINTED OUT MY COLOUR CHART TO SEND OFF FOR PROFILING, I DIDN'T USE THE ADOBE PRINT UTILITY TO PRINT IT. THEREFORE THE PROFILE WAS MADE BASED ON THE WRONG SHADES/COLOURS.
Steeki
Steeki89
Post by Steeki89 »
Does any of the 30 who viewed have any input please??
Thanks.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Post by JMugs »
My first line of attack would be check all your settings, very slowly.
Steeki89
Post by Steeki89 »
Hi JMugs,
Firstly thanks for the reply.
As for checking the settings, the following is what I have done thus far.
- Cleaned printing nozzles multiple times.
- Drew the ink through the lines using syringe.
- Printed nozzle check page. (all colours firing fine)
- On the printer's settings, I have made sure there is 'No Colour Adjustment'; the paper type is set to Matte; and the speed is High. (both used in the making of my ICC profile.
- I have deleted and re-installed the custom ICC profile.
- On Photoshop, I have deleted all previous settings back to default (in case I have hit something by accident.)
- On Photoshop's print page, I changed the 'Colour Handling' option to 'Photoshop Manages Colors' and selected my ICC profile from the drop-down menu.
Are there any more settings you think I should run my eye over?
Not sure if its worth pointing out that the Image was originally created on the program named GIMP, and opened in Photoshop.
The recent measure I have tried using is the Gamut Warning while tinkering around with the Hue/Saturation of the image. Although I have corrected the Gamut Warning colours on-screen, the printed image is identically wrong, as before.
My hammer is looking like the tool I will be reaching for next....
Steeki.
JMugs
Post by JMugs »
Is the original image RGB or CMYK, what does the preview screen look like?....
Just a another thought... printing on the right side of the paper?
Janners
Steeki89
Post by Steeki89 »
i think my workspace and the original image are both in RGB. Yes, correct side of the paper.
JMugs
Post by JMugs »
Is your screen profiled? If it isn't then your screen colours may be off.
Steeki89
Post by Steeki89 »
How do I know if my screen is profiled, or if it needs profiled?
After sublimating, although the turquoise is trying to come through, the entire image seems darkened.
I am using a 3d vacuum heat press with temperature at 200oC for a time of 8mins. I tried a mug with reduced time but the image only partially transfers.
Could my temperature be too high?
Steeki
JMugs
Post by JMugs »
If you need to ask is your screen profiled then no it isn't. I don't use a vacuum heat press so can't be much use to you with times and temps.
Steeki89
Post by Steeki89 »
UPDATE: after many emails between my suppliers and I, it seems that I may have created the ICC profile wrong. When I printed out the colour chart, I may have used the standard print command on the file, as opposed to printing via the Adobe Colour Print Utility.
I will send away the new chart, have a new profile made, and if this is the solution to the problem, I will update the threat as Solved.
