Website Meta Description
Area to discuss all forms of website,design, commerce etc.
jampers
Re: Website Meta Description
Post by jampers »
I have updated all of my website meta descriptions for my website however when i search for my website using google i don't see the description under the website heading.
I have attached an image to better explain.
vB_ID:3465
vB_ID:3465
printosaurus meta description.JPG (18.17 KiB) Viewed 604 times
All of the grey text should be the text that sells my website so to speak yet i cannot get this to show.. Does anyone know where i'm going wrong?
I'm using Opencart by the way
Thanks in advance
Enzo
spongerobinson
Post by spongerobinson »
It usually takes google a while to index these things, so if you've only just made the changes I'd give it a little while. also, if you haven't already done it, submit a sitemap to google using webmaster tools.
Skye
Post by Skye »
spongerobinson;101374 wrote:It usually takes google a while to index these things, so if you've only just made the changes I'd give it a little while.
Spongerobinson is correct.
Also Google doesn't always take your description if it thinks it can do better....... There are plenty of articles about google's methods, search with "meta description not showing".
If you put site:printosaurus.co.uk into google it will show you all your pages with their descriptions. You can then check which ones google is changing, though I don't remember if it shows the latest data or data from the cached copy.
Karen
daviddeer
Post by daviddeer »
The site description is taken from all the information above the header on your site. If you could move the currency/login module/div down and place a site description first on your site or at least directly after the header image this would show on google. Site descriptions are taken from the wording on the site not the metadata "description". Google shows what it encounters first when spidering the site
Therefore it shows the text in the following html:
€ - Euro
£ - Pound Sterling
$ - US Dollar
My Account
Wish List (0)
Welcome Login Create an account
And so on.
A general rule of thumb for opencart is;
Header image
Title (h1) [short title]
Short description [trying not to use stop words like and/or/,/. This is repeated on web page elsewhere as keywords and in metadata as description and keywords]
The rest of your site.
Stitch Up
Post by Stitch Up »
Jeez! I wish I had a better understanding of this sort of thing!
We badly need some SEO (I think) :)
Is there a noddy's guide that even a complete novice will understand?
FutureProject
Post by FutureProject »
our google presence for our home page uses our meta description or og:description tag which is designed to be eye-catching in the results, there's various tricks and tips you can use to get good google presence, but there's no "this is the guaranteed way to do it" I assure you our site is far from using daviddeer's "rule of thumb" above.
The only sure way to get a good google presence is hard work, good content and patience, avoid the quick tricks, short cuts and hacks as you may get good results short term you'll get kicked to the curb the next google update and even black-listed.
spongerobinson
Stitch Up;101409 wrote:Jeez! I wish I had a better understanding of this sort of thing!
Not exactly a noddys guide, but some useful info, and straight from Google.
http://static.googleusercontent.com/med ... -guide.pdf
Alox
Post by Alox »
your website is expired. But if someone have the same question, here can be an interesting info.
Like spongerobinson says, Google has to crawl your page in order to update it. If you want to know the last time when Google crawled your website do this : Go to google.co.uk, next copy and past the URL of your page (index page if you want to check if Google crawled this page), after that click on the down arrow (on the right to your website title) and click on "cache". A new page is loaded and on the top of this page you can see (for example): "affichée le 26 juin 2015 01:54:13 GMT". I'm french so it wrote in french but in english it could be something like this : "This is the page when we crawled it the 26th June 2015 at 01:05:13 GMT".
If you modified your meta description before this date, you have to know that a meta description has to be inside the . And the code is :
--> I'm sorry, I don't understand why but I can't publish HTML code.
Bye ;)
logos unlimited
Post by logos unlimited »
HI, if you put your full website address into majestic seo or ahrefs you can have a look at your websites health on seo ,which is great to see what you need to work on .
kind regards logos unlimited
