MDP mug press. Read here owner review and pics.
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Re: MDP mug press. Read here owner review and pics.
Take a side pic of the mug in the press with it closed.
The problem is you have a press which is most likely a clone.
When the handle gets to the halfway point you should start to feel a light pressure on the mug.
The spring loaded bolts should never be moved.
bear in mind its a FREESUB which I stated at the beginning, [ATTACH=CONFIG]6703[/ATTACH][ATTACH=CONFIG]6704[/ATTACH]yours probably doesn't say FREESUB.
heres x2 picture of side view and front.
- vB_ID:6704
- IMG_1989.jpg (88.81 KiB) Viewed 842 times
- vB_ID:6703
- IMG_1986.jpg (81.2 KiB) Viewed 842 times
- Mrteajunkie
That looks tight enough to me.Tony4415;148402 wrote:bear in mind its a FREESUB which I stated at the beginning, [ATTACH=CONFIG]6703[/ATTACH][ATTACH=CONFIG]6704[/ATTACH]yours probably doesn't say FREESUB.
Open the press tighten the thumbscrew and close it again.
dont get me wrong it needs to be a snug fit but not really tight fit.
as long as the mug doesn’t move in the press when closed.
Ok I thought it had to be firm pressure I read this on this forum, like medium to hard pressure to get good image contact.
I will try as is at the moment with both screws tighten (light-medium pressure) tomorrow.
but thanks with all your help today, much appreciated. top man!
- Mrteajunkie
If it comes to it take a video of the handle going down so I can see what pressure your applying and how your interpretation of firm compares to mineTony4415;148404 wrote:Ok I thought it had to be firm pressure I read this on this forum, like medium to hard pressure to get good image contact.
How do you upload a video file?
Do you have email address please?
well I don't know how to upload a video file.
If I explain... I can close the press with 110z mug inside with my index finger, light pressure.
- Mrteajunkie
pmd you email.Tony4415;148407 wrote:well I don't know how to upload a video file.
- Mrteajunkie
Looks good to me fella.
have a trial run and let us see the result.
