umbrellas
Re: umbrellas
Morning all, I bought 2 (yes 2) red and white umbrellas to try dye sub on. It's maybe me but I can't find any info on heat and time setting's. Can anyone help? Pipesy
Re: umbrellas
190 degrees 30-40 seconds. Be very careful when you print these to ensure you lift the heat press gently as if you do it too quickly then you might lift the paper and it could drop down onto the umbrella again (in a slightly different place) and leave a ghosting image.
Re: umbrellas
Been there, done that, ruined the tshirtBe very careful when you print these to ensure you lift the heat press gently as if you do it too quickly then you might lift the paper and it could drop down onto the umbrella again (in a slightly different place) and leave a ghosting image.
