Metallic Films
Re: Metallic Films
I'm having trouble with metallic (silver/gold) films and also Numbers (bought pre-made) sticking to t-shirts after heat pressing. I've followed heat instructions and even set it higher and lower but still they don't stay put. What am I doing wrong? Any ideas
Suzanne
Re: Metallic Films
Not at all??? Do you cold peel them?
Re: Metallic Films
Are you taking the backing sheet off when hot or cold, if hot try waiting until its cold before peeling.
Re: Metallic Films
Do you pre-press? Sometimes the added heat can cause a normally hot peel material to fail to stick. Many of the metallic foils - the mirror or holographic look materials - are cold peel or at least wait to cool a bit before peeling. Then press for a couple of secs after peeling.
What sort of Tees? Polycotton / polyester hold heat longer than cotton so wait a bit before peeling.
alan
alan
Re: Metallic Films
I don't generally pre-press unless the tshirt is really creased. I still can't work out where Im going wrong. I have the same problem with vinyl. The instructions (vinyl) say 10 secs at 150c and cold release. The only thing I can now think of is that Im doing something wrong. Should I be placing the teflon sheet over the carrier sheet ( as I have been doing) or could that in some way be acting as a barrier so the heat is wrong, if you get my drift? I've just watched one of Pauls videos where he doesn't use teflon and after he's removed the carrier sheet he presses again striaght onto uncovered vinyl. I assumed it would stick to the heat plate if I did that?
Re: Metallic Films
I always pre-press due to the moisture held in the material.. some flex will allow you to get away with not using anything over the top.. but some won't
After pressing.. I then remove the backing, cold or hot depending on flex and then press again with sheet over the top as I don't have a teflon coated press.. and it would melt to mine lol..
Maybe it's worth trying a pre-press with this ??
Re: Metallic Films
Can I just check again when you first press the vinyl, do you still use teflon over the carrier paper or not?
Re: Metallic Films
I use a sheet of silicone paper.. no matter what I do.. but that's just something I have always done
