sublimation wooden clock video
Re: sublimation wooden clock video
Great tutorial again Paul :biggrin: Just one thing about the prepress in that it would have been better if you had used some paper underneath & on top of the clock to protect the press from the moisture.
good point...Ian M;57361 wrote:Great tutorial again Paul :biggrin: Just one thing about the prepress in that it would have been better if you had used some paper underneath & on top of the clock to protect the press from the moisture.
WorthDoingRight;57330 wrote:Paul, would you not normally pre-press the item you were 'drying out' with the sublimatable side facing the heatpress?
Another tip is to push a pin through the centre of your sublimation paper to mark the clock face centre. Then you can align the centre of the clock to the base visually much more easily.
But great video again and looks a quality item.
i had a thought about this and i know why i decided to pre press it upside down
is coz of warping. i wasn't sure if clock will warp or not. so if it will warp after pre pressing it will wrap back after final press. i hope this make some sense
regards to pin the middle.
if you look closely at 8:00 of the video you will see there is a small white circle. software i presented always print one for you right on the middle so its easy to position
Hi Paul,
I just had a look at this video after seeing your 'frosted glass' video - another great one, well done buddy
Question though please. Do you not normally put anything down to protect your bottom plate when sublimating an item? The clock was face down so the ink would escape onto the bottom plate and 'could' transfer onto another item. I use baking paper under and on top (go through loads of it) but it is frightening of how much transfer (ink) escapes in the press and goes onto the baking paper.
It all depen if i remember or not lol
I didnt this time. But this press is like new and didnt had much sublimation presses yet.
Any way... I never had any ink transfered in my life so i think i can class myself lucky
