contour cutting
Any OS, software in here.
plugy
Re: contour cutting
Post by plugy »
i would like to know if there is a way to contour cut around the letters on the logo away from thebackground.
I have photoshop, corel, and flexi but am a beginner so please explain if anyone has a clue thanks.:frown:
vB_ID:1077
vB_ID:1077
WorthDoingRight
Re: contour cutting
Post by WorthDoingRight »
Would you be able to confirm what the cutter is you have and does it have any form of either optical or laser for contour cutting?
I know that Flex allows contour cutting, however I have no idea whether your cutter has the contour cutting feature.
Assuming it does then theoretically you could produce a contour to cut around the letters, but again how much of this can be automated and how much requires you to draw the contour to cut I am not aware.
As I cannot offer any more wisdom than this I will leave it for an expert to come up with the answer and good luck in getting your solution.
Richard
Re: contour cutting
Hi. You dont need laser pointer or optical eye to contoir cut. And not every flexi can cotour cut. I think this feature is.from flexi starter 10. I think in previous ones you.was not able to.do that.
Any way. If this graphic is a.vector.file then there should not be any problem to cut aroind it :-)
WorthDoingRight
Re: contour cutting
Paul;49113 wrote: If this graphic is a.vector.file then there should not be any problem to cut aroind it :-)
Well I was working on the fact that it appeared to be a jpg created with I imagine an online cool text generator lol
Having struggled just to assemble a stand and mount a cutter on it from the chinglish instructions I have as yet not had the courage to attach it to the pc yet. Although I am looking forward with trepidation to trying signcut, flexi and signblazer out to see what works.
