Epson B1100 - Constant Blockages!!
Re: Epson B1100 - Constant Blockages!!
A quick question - this may be unrelated, but are you experiencing problems when your cartridge ink level is at the lower end? (i.e nearly empty)
no got to sell the boatPaul;44718 wrote:New boat steve??
so bought a big static caravan on a holiday site we now have 3 bedrooms lol
and also got an industrial unit although haven't got it sorted yet
the only way it might work Karen is to use a syringe and physically put the ink into the carts
this would work for a short time until it wanted more ink but worth a go as a stop gap
If it gets things going I'll try anything!! Where would I syringe the ink into? Presumably through the bung used to reprime?smitch6;44721 wrote:the only way it might work Karen is to use a syringe and physically put the ink into the carts
Only with Epson refillables...Paul;44695 wrote:bin your ciss and use refillables... more refilling
Yeah
...Or buy brother and use your ink you already got1
Thanks everyone for your advice, much appreciated!karens;44730 wrote:If it gets things going I'll try anything!! Where would I syringe the ink into? Presumably through the bung used to reprime?
I managed to syringe a bit of magenta directly into the cartridge and, lo and behold, the prints were coming through perfectly - still can't work out why syringing magenta cleared the other missing nozzles but hey-ho!!
Anyway, I have managed to produce the stock needed for this week and I'll worry about what I'm going to do with it all next after the weekend. Although it does seem refillables are the future...
Thanks again, if it weren't for the forum and your help I would definitely taken a sledgie to the whole thing by now!
Karen x
Doesn't seem to make any difference with mine to be honest, I have problems whatever the ink level!! :-/AdamB;44719 wrote:A quick question - this may be unrelated, but are you experiencing problems when your cartridge ink level is at the lower end? (i.e nearly empty)
Hi, we're having the same problems. Only with Cyan tho' !!
Printer only purchased back end of 2010 along with ciss.
Have tried all methods indicated in this thread including refillable carts, but to no avail.
Think I'll bin it and splash out on an A3 Ricoh........
May try the Magic Bullet method first!!
If that doesn't work then I'll use the Silver Bullet method.
Barry.
Barry.
