iPhone Cases - Time & Temp
Ian M
Re: iPhone Cases - Time & Temp
Post by Ian M »
Just did my first couple of iPhone cases today & they have come out more wrinkly than a prune on the surface.
I pressed them at 180 degrees for 50 seconds & also pressed them one with the metal underneath & one with the metal on top. My settings were ok because I had just pressed 100 pieces of metal which were all perfect.
On top of this I had a nightmare putting the insert onto the case because I got the ones with the seperate piece of double sided & boy is that ultra sticky.
Would be very grateful to find out what everyone else is using as far as time & temp.
Many thanks. :biggrin:
Ian M;43221 wrote:Just did my first couple of iPhone cases today & they have come out more wrinkly than a prune on the surface.
Did you remove the protective plastic on the surface of the metal sheet? I presume these came with that on.
Ian M
Post by Ian M »
bms;43225 wrote:Did you remove the protective plastic on the surface of the metal sheet? I presume these came with that on.
Oh yes I did Martin having had to remove it on all the pieces of metal I had just pressed before the cases. In fact they come out looking like the protective film is still there to be honest.
Ian M;43226 wrote:Oh yes I did Martin having had to remove it on all the pieces of metal I had just pressed before the cases. In fact they come out looking like the protective film is still there to be honest.
That is strange. Can't imagine why the metal would go wrinkly as it should be a flat smooth surface - the temp and time is about right. Perhaps the coating melted. If other metal you pressed was okay then it sounds like a coating issue. Possibly go down to 180 degrees for 40 seconds to see if the lower temp helps. What did the supplier suggest?
Ian M
Post by Ian M »
I think it also could be the coating that is the problem Martin. In fact watching their video their finished inserts have the same wrinkly surface as mine. The easiest option is just to get them from you & then I know they'll be good.
I contacted the supplier a few weeks back when I had a problem with their Orca mugs cracking in the press & even had a handle fly off at one point & still waiting for him to call me back so, don't think I'll bother again.
Many thanks for your help Martin :biggrin:
michallatal
Post by michallatal »
Ian M - in two months I had 3 different type of alluminium sheets for iPhone covers, all with different finished results.
I am pressing metal at 190 for 55-60sec with image face up.
Personalised gifts and products
<a target="_blank" href="http://www.owngifts.co.uk/">http://www. ... .co.uk/</a>
Ian M
Post by Ian M »
Many thanks Michal. I think Martin has hit the nail on the head as it does look like the coating is the issue here.
AJLA
Post by AJLA »
Hi Ian, I was pressing at 190 for 60 secs with the same result as you. I have now dropped my temp to 175 for 75 seconds and the result is unbeleivable its as smooth and shiny as glass.
Funny tho every one I have seen out there printed by other companies has been rippled...Not mine:smile:
Ian M
Post by Ian M »
Hi Mandy, many thanks & will give your settings a try :biggrin:
purpledragon
Post by purpledragon »
Ian
i gotta say im selling a few of the i phone cases i get them from martin pressed @190 for 60 secs and each one has been perfect (apart from when i forgot to remove the plastic but even then it went through to the metal ok )
Brett
ps martin still waiting for that fiver you promised 2 years ago
