I know you can add contour cut line within Flexi. I have a file that was created in Coreldraw with cut line. Flexi recognises the cut line so I don't have to recreate.
I want to do the same with another image for for the life of me can't get Flexi to recognise the cut line. Not sure how it's recognising the other file, trying to work that out!
Anyone any ideas? The first file was made to cut in Versworks with the cut line a certain colour to be recognised, I've tried changing the colour to the same but still no go.
Flexi - Adding Contour Cut Line
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 3 times
Re: Flexi - Adding Contour Cut Line
Are you using the versaworks swatch file to create the cut line?
its 100% magenta at 0.25 if I recall.
Have you named the CutContour and Artwork layers to the corresponding names
Was just about to post again, thnik I've sorted it....rookie error!
I hadn't named the 'CutContour' Just testing again now but fingers crossed!
yep. is not about the colour of cutline. It can be just any colour you wish to use. name is the important part
