ST3042 membrane bursting
Phil7465
Re: ST3042 membrane bursting
Post by Phil7465 »
I keep seeing videos of the ST3042 on YouTube doing plates at 195 degrees for 7 or 8 minutes. It was taking me 15 minutes at the same temperature to do a 10 inch plate. Then the silicone membrane after the 3rd plate. I replaced it with the spare one I got with the machine from Signzworld. I have lowered the temperature to 160 but it is taking over 20 minutes to do a plate now. Can anyone help?
Have you got both ovens turned on?
Phil7465
Post by Phil7465 »
Yes. Both ovens are turned on although I have to say it did a good job but seems too long. Thanks for your reply.
The gauges on the vacuum presses are woefully inaccurate so I wouldn’t worry too much about time or temp as long as you are getting good results
Phil7465
Post by Phil7465 »
Thanks again.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
