Any ideas anyone? Printing/etching on glass/plastic
Discuss other print methods.
Re: Any ideas anyone? Printing/etching on glass/plastic
Mikejohno1;127384 wrote:I'll try that today actually. I will spray the inside of the glass I think. Would you recommend removing the vinyl stencil when the pain has dried or whilst still wet?
It dries very quickly. You should be able to remove the stencil after just a couple of minutes. Apart from stencils, great effects can be obtained by, say, criss-crossing a sheet of glass with strips of insulating tape, or criss-crossing a wine glass with elastic bands before spraying.
Reg
Post by Reg »
This is what I use - http://www.diy.com/departments/valsp.../184225_BQ.prd but others are available from the likes of Rust-o-leum and Plastikote. It makes a very smooth, unblemished surface, just like etching, but so much easier and cheaper. Hard-wearing and I've even hand-washed the bottles I decorated (to make lamps).
I fail to see how this is easier or cheaper than my method as the process is the same,but using acid etch creme you can remove the excess and reuse it after you've etched the glass were as with the spray once it's done it's gone.
