Sublimation Aluminium panel printing
Re: Sublimation Aluminium panel printing
Is this Chromaluxe? Always a good idea to print bleed and wrap around to avoid those white edges
Also a good idea to use Endura fabric to capture gasses.
I print Subli metals stock upside down as you did, Sawgrass engineer who visited me last week told me they never advise this
I don't wrap around, but I do print a couple of millimeters bleed all around, lay my alu sheet over the wrap, then tape over 2 edges. I press between 2 sheets of paper.
I press at 200/60 but the real 'secret' I find is to use hardly any pressure at all, basically just the weight of the platen plus a tiny bit more to avoid the 'marbling' effect.
i love to print some bleed but this is what my printer can do
and no more
time to get something bigger. looking for A3+
ps. no, no chromalux. standard, white aluminium panel.
Yeah, I print mainly to alu sheet sized to the Ricoh print area (just less than A4 as it can't print borderless). This allows me room for a bleed and some tape.
Looking into Chromaluxe just now - http://www.xpres.co.uk/p-9213-chromalux ... xpres.aspx which is 203.2mm - literally 1mm shorter than the print area of the Ricoh. Is it the photo panel as in the link you are using?webtrekker;121423 wrote:Yeah, I print mainly to alu sheet sized to the Ricoh print area (just less than A4 as it can't print borderless). This allows me room for a bleed and some tape.
This is the metal I use -
https://www.sublimetals.co.uk/product/a ... -a4-ricoh/
I use the white and the white ultra glossy and get edge-to-edge prints with room left for a bleed.
https://www.sublimetals.co.uk/product/a ... -x-200-mm/ this is the one ideally i would like to use - but think i might be cutting it a little bit fine, as long as it it doesn't overlap it i should be fine. Might give them a shout tomorrow:)
Have you got you Ricoh set to maximum printable area in the driver?
The ultra-glossy does have a noticeably glossier surface than the one classed as 'white.' It's almost mirror-like and worth ordering a sheet or two to see the difference. Sublimetals also sell plastic and card stands for the sheets to make them free-standing.
