Blacks are Printing Purple HELP!!!!!
Redboxinc
Re: Blacks are Printing Purple HELP!!!!!
Post by Redboxinc »
Hi All,
My first post so hello to all.
I'm doing some samples for a client. They are simple charcoal Sketches witch they want on mugs and coasters.
Here leys the issue! When I print via Photoshop CS5, using the latest driver for Ricoh SG3110dn and the Power Driver they print purple. I have set the files to RGB and set the print setup to Black and White and the result is not purple but a strew yellow.
I am using the profile SG_SG3110DN_RGB_SJr_v1.0 and the print setting as outlined in the config doco.
My colour prints are great, just these once are causing me big issues...
Please help.
KathG
Post by KathG »
Are you choosing Powerdriver from the printer selection box? Also have you tried to print as the colour on the paper does not represent the actual colour once printed.
Kath
Kath
Redboxinc
Post by Redboxinc »
KathG;102887 wrote:Are you choosing Powerdriver from the printer selection box? Also have you tried to print as the colour on the paper does not represent the actual colour once printed.
Kath
Hi Keith,
I don't have the option for the power driver in the printer drop down list. I select the Ricoh. I have printed the colour chart that comes with the powerdriver and the greys are more a purple.
KathG
Post by KathG »
Have you been to the SawGrass website to download the Powerdriver software ? If not you need to do that, and follow the instructions to set it up. Then you will have the option to pick the Powerdriver as your printer.
You won't get the right colours straight from the Ricoh drivers. I will go get the link for you.
Kath
Redboxinc
Post by Redboxinc »
KathG;102895 wrote:Have you been to the SawGrass website to download the Powerdriver software ? If not you need to do that, and follow the instructions to set it up. Then you will have the option to pick the Powerdriver as your printer.
I am on a MAC so your saying that if I install the powerdriver I should be able to see a PowerDriver as a printer selection...?
KathG
Post by KathG »
Hi again
Here is the link. From here choose your ink and then printer and operating system. This will take you to the correct drivers for your printer.
BTW you only use the Powerdriver with Windows operating system. If you are using a Mac, select that and you will be able to download an ICC file for your printer.
hope this helps
Kath
http://www.sawgrassink.com/Portal/Tech- ... ort-Wizard
edit....LOL... You beat me to it. On the Mac there is no Powerdriver, but they do provide an ICC profile for the MAC
Kath
Redboxinc
Post by Redboxinc »
I am using the Ricoh SG3110dn & the SG_SG3110DN_RGB_SJr_v1.0 profile.
I think it may have something to do with RGB in the colour setup. Sawgrass in the setup video https://www.youtube.com/watch?v=Uqqgf-jwzk8 set the RGB to sRGB IEC61996-2.1 and their doco they say to use RGB 1998.
I am in the process of trying both.
definitely colour space of Adobe RGB 1998, Photoshop manages colours, and then print to the Ricoh driver - make sure there is no colour adjustment or enhancements in the printer driver itself. Use whatever other settings that Sawgrass recommend (resolution, and paper type etc, as all of these things can shift colours slightly.) Also, you need to be using the paper that was used for the creation of the profile, as different papers also shift the colours. For best/optimum results, a bespoke ICC profile made for your individual printer is the solution.
Users browsing this forum: Baidu [Spider] and 3 guests
