Trying to find a solution for iphone blanks corners... We can do it! :-)
3D Sublimation
Re: Trying to find a solution for iphone blanks corners... We can do it! :-)
I'm happy to make my templates available for others to use - is there somewhere specific for me to upload them to, can anyone let me know?
There is a downloads section of the forum that you could use. I certainly would be interested in some of your templates.
I also have thought of something else to make it all even better but need to try it first, if it works I will share...
membrane
Post by membrane »
socialgiraffe;90132 wrote:I also have thought of something else to make it all even better but need to try it first, if it works I will share...
Hope it works for you, and that you'll share! :cool:
ArtyGamer
Post by ArtyGamer »
ArferMo;90131 wrote:Great.... Super.... sussed it your vacuum is pulling much more than mine I only get to 0.6 and its not pulling the corners in tight enough.
Where's me tools could be a split pile or loose connection.
LOL after watching your video I picked up my phone to see who had just messaged me LOL
Split hose... you should try the hoses that I now use. Can't remember the name of the thread.. ah, the power of a search!
http://www.dyesubforum.co.uk/vbforum/sh ... cuum-hoses!
I love that you thought you had a message come through! My notification tone used to be the Xbox achievement 'plink' which, in a room with twenty gamers all chatting while someone is playing on the Xbox, is hilarious as all heads turn to the screen to see what achievement has just popped.
socialgiraffe;90132 wrote:There is a downloads section of the forum that you could use. I certainly would be interested in some of your templates.
Awesome, I'll upload those later tonight. If it fails, I'll go with Dropbox instead.
guarddog14
Post by guarddog14 »
im so glad to hear about batman game lol have every one of the games on origins now but i prefered arkham asylum even though it seemed less graphic wise .
membrane
Post by membrane »
Attempted again today. Finally got good results using the above methods. Unfortunately, the heating element on my machine is now out so I have to order replacement parts for my machine. These machines are very low quality, mine has been falling apart slowly since the first week I had it.
[ATTACH=CONFIG]2867[/ATTACH]
[ATTACH=CONFIG]2868[/ATTACH]
[ATTACH=CONFIG]2869[/ATTACH]
[ATTACH=CONFIG]2870[/ATTACH]
vB_ID:2870
vB_ID:2870
vB_ID:2869
vB_ID:2869
vB_ID:2868
vB_ID:2868
vB_ID:2867
vB_ID:2867
Andrew
Post by Andrew »
Picking the right design as above makes your life a lot easier. Having said that, whenever we have had a go on the dark flat colours they have always printed well enough on the corners so not had a massive problems. There was a bit of folding/creasing going on but not a complex job.
ArferMo
Post by ArferMo »
Had a split in one tube luckily the same size as on the Omega, vacuum is better now and corners MUCH better.
membrane
Post by membrane »
It seems the more pressure from the vacuum, the better the corners turn out.
asfasf
Post by asfasf »
But how can you get more pressure? Mine shows 0.08. What about yours, guys?
