Epson B1100 custom profile.
Re: Epson B1100 custom profile.
have you got any other paper?
trial PS: https://www.adobe.com/cfusion/tdrc/inde ... &loc=en_gb
smitch6
Post by smitch6 »
email sent paul :)
yes i have some other cheaper stuff and the images look exactly the same on both
how i do these is
i open the image i want to use play about with resolutions atc and sizes to get it how i want it
i then open a new A4 blank sheet
and drag and drop the original item onto the A4 so i can print it out where i want it
will that make a difference?????
yep :) all documents use adobe rgb???
swimwivsquid
Post by swimwivsquid »
As long as the A4 sheet that you make is the same resolution as the images you copy on to it. Make the a4 sheet 300dpi and the image the correct output size also at 300dpi. Know it sounds obvious but its easily missed when working.
LOL :) I got the answer for you smitch :) your picture is only 603x602 so it may be your problem when you trying to resize it on A4 page ;)
smitch6
Post by smitch6 »
nooooo thats the size i'm testing it on lol
the biggest it'll be is 800x800
you should test in best quality :)
any way. I will press it soon that what you sent me and have a look.
smitch6
Post by smitch6 »
other images i try and print tend to come out dif as well
usually alot lighter than what the colours should be???
this is diferent story mate. this is down to your screen. It need to be calibrated as well. But lets sort your colors out first.
smitch6
Post by smitch6 »
that image was one that was sent to me
i haven't made any adjustments as all apart from to up the res
its one that was made by a web designer
