opencart !
Re: opencart !
you can either log-in to cpanel to collect it or if you have vqmod installed there is a mod which allows direct access from admin panel
Re: opencart !
Login to the admin of your OpenCart and click "View" to view the order that you're working on. On the "Orders" panel, click the "Products" tab and you'll see a list of products ordered by the customer. You should also see something like "Upload Image: .jpg" underneath the related product. The image name should be a clickable link which you can click to download.bassqee;45262 wrote:when a client uploads an image - where does it go?
If the customer has ordered other items, just do the same for the other images.
Re: opencart !
I don't have the vqmod installed.smitch6;45276 wrote:that only works if you have the VQMod installed btw
Re: opencart !
that works for me - no mod installed.JSR;45274 wrote:Login to the admin of your OpenCart and click "View" to view the order that you're working on. On the "Orders" panel, click the "Products" tab and you'll see a list of products ordered by the customer. You should also see something like "Upload Image: .jpg" underneath the related product. The image name should be a clickable link which you can click to download.
Re: opencart !
I'm using version 1.5.1.3 on my live site and I'm working on 1.5.2.1 on a copy of that while doing the upgrade. Both are okay with the image link in the back-end. I've never used an older version of OpenCart, though.smitch6;45279 wrote:they must of sorted it on that version then
Re: opencart !
also confirm that the above way works fine with 1.5.1.3 :biggrin:JSR;45280 wrote:I'm using version 1.5.1.3 on my live site and I'm working on 1.5.2.1 on a copy of that while doing the upgrade. Both are okay with the image link in the back-end. I've never used an older version of OpenCart, though.
Re: opencart !
Works fine for me on 1.5.1 also
Matthew
