Colour issues
Re: Colour issues
Hi Justin, yes have done and as in original post have tried a totally different profile to prove system was working ok and printed out a sheet with different colours .
Re: Colour issues
Hi Justin, yes checked settings and also tried totally different profile to check system working.
Re: Colour issues
Although the supplier may not be welcome, they still provide OKish mugs.
With regards to the time, are you setting 200 seconds from once the mug press is back up to temperature? If you set a mug press at 180 degrees, when you put the mug it the temp drops to about 150-160 degrees. When it reaches 180 again is when the 200 seconds should start.
Re: Colour issues
Hi Socialgiraffe, Yes that is the case.are you setting 200 seconds from once the mug press is back up to temperature?
The mugs do seem ok but they were the only thing that was left to change. I had had good results on ceramic coasters so from that, assuming the printing side is ok. I am printing artists artwork so looking for best possible results.
Re: Colour issues
Hi John G, Had not thought of that. It is new and have printed a few Durham mugs ok, that is not to say that the tapered insert may be faulty!
