Problems with my heat press
accdave
Re: Problems with my heat press
Post by accdave »
I also had similar problems with one of their presses, and the same non-response when asking if they sold parts or offered a repair service. The temparature was all over the place so it's now stuck under a desk at the shop and I bought a new one. I'll watch this thread with interest :D
Almost there! Can you take a picture of the top of that part so we can see the display and buttons - probably from the top of the machine?
DELLAROSE
Post by DELLAROSE »
Here it is
Thanks, I'll have a rummage around in our boxes of spare parts during the day and let you know...
DELLAROSE
Post by DELLAROSE »
Thank you. Much appreciated.
We have something that looks very similar, but not exactly the same. If you want to pm me your address then I'll pop this in the post and see if it works.
Have popped the part in the post tonight for you. No guarantees, but let us know if it does / doesn't work.
DELLAROSE
Post by DELLAROSE »
Ok will do. Thanks again. :)
DELLAROSE
Post by DELLAROSE »
Hi Martin Got the part today and fitted it in but now it just shows 617 instead of HHH. Don't know what to do now
That's a shame. I think your only option now is through the original supplier (or another supplier that resells/ supports those machines). We carry spare parts for all our machines so the supplier of your machine should do the same. If not then you might be able to get an electrician to look at the machine, but if the heat platen has failed then this will (a) be expensive to replace and (b) will have to come from the supplier of the machine.
