flex settings for craft robo II
Re: flex settings for craft robo II
Hi! finaly I get hold of some flex. I have done it in past but only couple of times. normaly I do flock. so can you remind me please what settings should I use with my CR???
thank you in advance
paul
paul
When someone who knows answers, can we make this a sticky please?
Perhaps a new catefory = Facts & FiguresGoldRapt wrote:When someone who knows answers, can we make this a sticky please?
Flex should be blue blade adjuster, pressure of between 8 and 14 depending on the sharpness of the blade and thickness of the flex and keep the speed at 10.
Always try the test cut first to quickly check.
it dont need to be sticky as yet. as we have in plans to do separate section for guides, tutorials, times and temps etc... so fingers crossed so we can introduce it asap.
thanx bms! very helpfull as always!
my blade is brand new so will start from 8.
thanx
again
thanx
again
What time and temp for that one? Same as for flock? I do that 180c for 20sec.
Time for flex - again, depends on which flex you're using. I tend to press ours at 170 for 20 seconds. Some are hot peal, some are cool peal. The hot peal ones are usually very sticky before you start. If you have the press too hot then you'll leave a glue mark around the edge of the writing!
I dont want any of that
