Did a tester tee with black flex cut sticky from Yolo , seems to be peeling slightly in areas, 165c for 17 secs on a fruit of the loom tee, not long enough or do you guys extend the print time or adhere to the flex cut sticky guidelines?
cheers
Slight vinyl peel
Re: Slight vinyl peel
Well, I have done a re-press for just 10 seconds on the press at the stated temp of 165c with silicon sheet over the print and it has sealed! Maybe in future I will extend the press time by a further 5-10 seconds just to make sure.
I use MDP hot flex and always pre press for 10 secs. Press the vinyl for 15 secs with a Teflon sheet remove the backing sheet and finally do a post press with the Teflon sheet for another 10 secs
I think I will up my pressing time to 20 seconds and do a re-press when cold for a further 5-10 seconds, hopefully that should do the trick in future!
- mrs maggot
dont wait until its cold to re-press, just re-press as soon as its peeled
HI
Do you re-press for the same time or just do it say for a further 10 seconds?
- mrs maggot
just a few seconds, it just makes sure that any vinyl edges that have "caught" when you released the vinyl will be back down
